It is currently Sun Aug 17, 2025 9:30 am
PostPosted: Wed Aug 27, 2014 2:34 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Found an old Koa Ukelele at a fleamarket, which has a couple of cracks on the top and back which are separated quite a bit. Afraid if I glue with hot hide glue and clamp, I'll break it. Not possible to join the cracks with hand pressure. Any ideas? Thanks.
PostPosted: Wed Aug 27, 2014 2:44 pm
They look very open, at least one of them does. Try to get some Koa and make some splints. It's the only way you are going to close those gaps.
PostPosted: Wed Aug 27, 2014 3:14 pm
I would first try to remove the bridge and humidify the heck out of it to see if they will close. I usually build some cauls by using the lower bout shape of the guitar to draw the shape to some cardboard then use that as a template to cut out some blocks on the bandsaw and line them with cork. Then you can use long bar clamps in an attempt to help close huge cracks liek that. After that splinting is the only option.
PostPosted: Wed Aug 27, 2014 4:08 pm
this I agree will be best served with a fillet.
PostPosted: Wed Aug 27, 2014 4:45 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
Corky I'm a flea marketer. How much did you get it for? If I may ask?
PostPosted: Wed Aug 27, 2014 6:52 pm
You might be able to close up a couple of the tighter ones by humidifiying and gluing, but the largest one should have a splint.
PostPosted: Thu Aug 28, 2014 9:05 am
First name: Corky
Last Name: Long
City: Mount Kisco
Thanks all for the recommendations. Looks like "a splinting I will go".
Lonnie - It was marked at 8 bucks - we got it for 5. A find, for sure.
PostPosted: Thu Aug 28, 2014 9:06 am
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Wow you lucky dog. I run across good finds occasionally. Man that's going to be fun.
PostPosted: Fri Aug 29, 2014 6:46 am
I don't think that humidification will help in this case. If you take notice the cracks are below the bridge and the top appears ok in front. The top did shrink behind the bridge and this may have been because of the brace structure. you certainly can try but this appears to be an older uke. Once the crack like this you most likely need the fill piece.
These users thanked the author bluescreek for the post: Corky Long (Fri Aug 29, 2014 9:50 am)
